vokera combi problem
23 Mar 2006
Leeds
i have a vokera linear 24 on which the c/h will not ignite unless i have the temperature set above at least 55 degrees when set like this it works fine anything lower and it ignites for a few seconds and then cuts out, the h/w works fine any suggestions?
Its an unusual fault!
My immediate reaction is that it may not be a fault at all as boilers are not expected to provide a CH temperature so low.
Has it always been like that or is it something which has changed recently?
Could I ask why you would want to have the temperature so low?
Tony
this fault has started in the last couple of weeks, it worked fine before and i could set the temp as low as i wanted. i didnt realise that i was using an unusually low temp setting as depending on the weather i have it set anywhere between 38 ish and 75 degrees.
