I have a Vokera Compact 24, have read through various posts on this site to try and figure out if this a simple problem that can be fixed.
I am getting hot water but no heating, the boiler fires on flashes the green light turns on and then off after a few attempts will fail and give the red light.
The strange thing is that if I have the hot water running for a while and turn on the heating at the same time I can then turn the hot water off and the heating continues to work. Turn it off and back on and it will not work.
I have read that it could be the pump, will test that later tonight when I get home.
Is there anything else it could be or anything else I should look out for?
