Hi, seeking some advice if possible please for Vokera Compact 28.
The safety valve is diverting water to outside, at a pressure of 3.5 bar.
I disconnected the filler loop (flexible hose) as i thought it might be filling. It was not and pressure remained high.
I removed water from system at a downstairs radiator to 1 bar pressure and the water stopped coming from the outside pipe, but the pressure then went back up to 3.5 bar in around 10-15 minutes.
If i have the mains water or DHW valve turned off the pressure will remain at 1 bar. If i then turn on and run the central heating with DHW valve still turned off the pressure rises slowly to around 2 bar and stays there. If i turn on the DHW valve the pressure rises quickly (a few minutes) to 3.5 bar.
Both central heating and hot water are working, but likely many litres of water have been coming out from the safety valve to outside.
I have read the forum here as much as i can and it seems it could be a an EV or HEX issue maybe?
Can anyone please advise, as i couldn't find my exact problem.
Thanks in advance, Mark.
