I have purchased the Honeywell THR872CUK wireless thermostat for use on a Vokera Compact 28SE combi-boiler.
The wiring diagram for the relay shows connections to the boiler on T1 and T2, which do not appear to exist on the Vokera (except within the mechanical timer).
Can anyone explain exactly how I connect this up please? Do I simply come in behind the fuse and connect L and N feeds to a separate connector or is there another to do this? The diagram supplied makes it look very easy but the actual connections in the boiler are different.
