Wondering if anyone can help me troubleshoot our boiler, the symptom seems to be as follows:
The water inlet pipe (for dhw) is fully open and there's good flow from the taps, so I don't think there's a blockage.
Any suggestions that I can use to narrow down what the problem is would be greatly appreciated. Thank you!
- Central Heating will run until the cows come home but if you start to use the DHW while the heating has been on for about 30mins the boiler goes to a solid red light.
- Resetting the boiler causes it to go green but if you keep drawing DHW and central heating it'll go back to red in about ten seconds. When doing this I took the cover off and looked through the little opening to see that the boiler isn't firing, it makes a kind of blowing noise and quiet high pitched kind of hum and then goes to red.
- Using DHW from a cold boiler is fine for at least the duration of a shower (so 20mins say). No red light.
- Turning off CH after a period of usage and then turning on DHW too quickly causes the red light. However turning off CH and giving it a few mins then using DHW seems to be fine.
