Hi
I have had a Vokera Compact SE boiler fitted and it has a mechanical clock timer. I had one on my previous boiler so thought setting it would be pretty straight forward.
This clock has 3 settings On, Auto and Off. I assumed Auto would be the timer setting, so i pushed the pegs out for the time i wanted heat, moved the slider to the Auto position and switched the boiler on.
It didn't work, i got heat constantly the boiler didn't switch off or on at all according to the pegs, so now i wonder if i've got it wrong.
Any help would be appreciated as the manual is pathetic and all it says about the timer is that there are 3 settings as already mentioned and that you need to push the pegs out.
Thanks in advance for any help
Gillian
Gillian
