vokera compact
15 Oct 2007
Humberside
hi im having problems trying to use my mechanical timer on my boiler
i set the time on the clock but when i try to move the swith to timer it seems to be very stiff
when it looks like its on the timer setting it doesnt come on, the switch only works when its on the on/off position but not on timer
can the timers be repaired or do you have to get a new one and will any vokera timer fit?
a fuse blow which i replaced does thew timer have a fuse or could something else be stopping the timer from working?
i dont want to buy another timer if its not that ive just priced one uo £70 :eek: :eek:
theres a digital timer on ebay that he says fits my boiler (as well as other makes and models) will this work?
ive got a mechanical one on at min
the mechanical and electronic ones for this model swap over no problem. they have the same connections at the back.
make absolutely sure its for your model though
