Vokera Easi Heat Plus 29C Flashing Green Light
6 Jul 2020
Hi folks, Vokera boiler has a slow and steady green flashing light past few days. Central heating for the flat is not working as a result, however, I do still get hot water and the boiler fires up whenever I'm running a hot tap.
I have tried turning it off for a while and turning it back on, but that didn't change anything. Pressure was initially at 0 when I realised the boiler wasn't coming on, but have boosted it up to near enough 1.5 mark and it has stayed there since.
Does anyone have any suggestions?
The slow blinking green LED simply means that the boiler is in stand by, there is no demand for heating, you have an external control failure, check the room thermostat and timer or whatever you have , if you are not sure post pics of what you have
Also remember turning the boiler off at the mains does not reset the boiler,only turning the selector through standby fro heating and not water and back does that.
Green light
0.5 second ON followed by 3.5 second OFF = Standby
How old is the boiler, is there a display and if so what is the display showing?
Appreciate the quick responses, I messed around with the thermostat and that's done the trick. Sorry to have taken up your time when the solution was so easy!
