Vokera Easi heat Red light
29 Jan 2023
Evening,
My Vokera Easi heat boiler has been working fine, pressure droping slightly recently but assumed this was due to increase in use, no visible leaks etc and all of sudden the red light has come up this morning.
Have reset and the boiler comes alive for 2 mins then the red light reappears and goes dead, I have made sure water pressure is right.
Any advice, Before I call out a plumber?
I
A bit of a stab in the dark to be honest,as really need to be in front of the boiler to be sure, because we are not allowed to give gas advice on here would need to know more and as long as the gas supply is on and working correctly then likely to be something in the ign side either a gas valve problem or ign unit but could also be others, best bet to be honest is a Vokera fixed price repair and at least you know it will be sorted and no surprise charges, where in the country are you ?
