I hope someone out there can give me some good advise.
I have a VE80SP mounted in the bathroom with the flue going through the wall. The outlet is in a driveway. The vent is approx 5m from ground level. In windy weather the burners on the boiler keep blowing out (this only happens when its windy). I assume that the draught that is whistling down the alley is entering the flue terminal and blowing the flame out. The boiler fires back up right away no problem. Can you buy cowls that have internal wind flaps that stop this problem? This problem is driving me nuts!!! since when its windy the hot water cycles from hot to cold as the burners are on and off. In calm weather the boiler works fine
I look forward to you answers
