Initially the boiler wouldn't work at all. Then it was discovered that it had a blocked venturion.
Hot water
The tap nearest the boiler will get hot water in 20-30 secs after the boiler has kicked in.
The bathroom (room below the boiler) will some take 3mins to get hot water, if at all. Sometime you need to go upstairs, turn the tap on nearest the boiler, wait for hot water and then hot water will be coming from all taps.
Central Heating
I am not getting any central heating at all.
The boiler sounds as if it's on. But the rads are all stone cold and the boiler itself isn't warm, like it is when the hot water tap is running.
Any solutions to this?
Thanks,
Ross
Hot water
Central Heating
Thanks,
Ross
