Old vokera is going to be replaced in the spring, therefore trying to keep it alive until weather and cash permits.
The problem; The hot water side failed completely, freezing cold all the time, so having researched the forum, looks like the diverter valve gubbins would be prime suspect. I've therefore fitted a complete service kit and now the hot water works, but only when heating is on. When DHW only is selected, the boiler won't go into the start sequence.
I'm assuming, because the hot water is fine when radiators are on, that the hydraulic side of life is fine, and I'm leaning towards the DHW micro switch either not working the diaphragm pin isn't operating it? It's difficult to see when the system is operated. Either way it sounds electrical. The fault tree in the manual isn't particularly helpful.
Does anyone have advice or similar scenarios?
Been on here for years, but lost my previous ID
Thanks in advance.
Thanks in advance.
