Vokera Flowmatic 24-96 RSE Ignition control box
The one I have is a Brahma with a multi-spade connecter block which houses 8 wires.
6 wires go to a printed circuit board and 2 go directly to a pair of igniters.
The date on the box is Feb,93
the fault manifests itself occasionally, it will fire up on request, run for 8 seconds then cut out leaving only the fan running then when I disconnect and reconnect the terminal block with the power still on it sometimes works normally for days,weeks,and maybe even months.
Its at its worst when I've been away a while and its not been running.
...Q-Is it an intermittent fault in the box or is it elsewhere? Can anyone please shed any light?
Reluctant to replace the box in case the fault lays elsewhere.
Many thanks in advance, Anderz.
