HI, i have a vokera linea 24 combi boiler,the hot water is working okay but
the central heating is'nt. The led on the front panel is green and is not
showing any fault codes.I have just replaced the mode selector switch and
both other switches appear to be okay. I have taken off the motorized valve
and this is working fine when i turn on the hot water the pin comes out.
I have checked the timeclock and this was okay, have also made solid link between terminals TA & TA.
The boiler fires up when i press the combustion check switch behind blank
screw on front panel and the radiators warm up. The boiler was switched off
for a few weeks prior to not working.
Any help offered would be most welcome and very much appreciated,
thank you.
thank you.
