I have a 6 year old boiler which has had many problems largely due to the regularly mentioned heat exchanger scale problems - now have a water softener and far fewer problems. A recent and new problem is a rattle that appeared to come from the main heat exchanger now changed and further investigation points to the region of the water manifold - pressure switch area. I recall someone mentioning a weak valve return spring as a possible cause of noise in these boilers but can't find the post/thread again!!!
Any help appreciated the MHE is new and the DWE is a descaled swop (I have 2 one on standby very hard water here)
Tony
Tony
