I have a vokera linea 24, the central heating is working fine, however the DHW has started to play up. (ie) turn on a hot tap boiler fires up runs for 30 secs to 60 secs then the burner cuts out the temperature drops on the display and the burner will cut back in. if in the shower water will be hot then cold etc.
I have changed the hot water thermister part number 8484, this made no difference.
the thing that confuses me is that just before the burner cuts out the needle on the pressure gauge for the central heating starts to bounce a bit. and when the burner cuts out it steadies again.
(don't know if this has any relevance or not but it dosen't happen any other time)
can anyone help ??
can anyone help ??
