Hi
I've been having problems with the hot water from the boiler for a couple weeks, seemed to be cycling from luke warm to cold in a matter of 5-10 seconds. Having found a few useful threads on here from people having similar problems I managed to determine that the problem lies with the three way valve. Stripped the casing off to find water leaking from behind the motorized valve and ordered a valve overhaul kit in the hope that this would cure the problem.
In the time it's taken for the kit to arrive the boiler has since popped a fuse and is now totally off.
Water has got into the motorized valve so I realise that I'm going to have to replace this too, but I set about replacing the 3 way parts anyway hoping that I could at least stop the water leak and get the boiler back running even if just heating or just hot water.
The kit comprised a new bobbin, O ring, washer, seating plate, rod and cover gasket.
Having fitted the new parts I tried to pressurize the system only to find that I was still getting a leak out of the end of the valve cover, where the motorized valve mounts. looking down the end with a torch it looks to be passing around the control rod where it comes through the brass fitting (gland?) within the 3 way valve cover.
Anyone know if this brass fitting can be replaced? Does the bore become worn? It seems like the rod to bore fit would need to be very precise to stop water passing here and if I can't get it to seal it's pointless fitting a new motorized valve as its going to go the same way as the original.
Any help please? Not fancying a cold, cold Christmas.
Cheers,
Dan
Cheers,
Dan
