Vokera Linea 28 clock wiring
9 Jan 2008
Fife
Does anyone know where I could get the wiring loom to fit the internal clock for a Linea 28? My boiler does not have the wiring fitted. I was thinking of buying one of those RF controllers that fits in the clock space in the boiler.
As an aside, I'd like to thank the experts on this site with their help in sevicing my boiler. A simple search revealed that I needed to re pressurise my expansion vessel, and that the rattle I'm getting is from the non return valve at the domestic hot water heat exchanger.
Is there a kit I can buy to refurbish the valve?
Cheers !
What with only 2 wires!! The digistat is a switch with an inbuilt relay operated by batteries so run a 2 core flex from room stat connection on boiler. If you are using a wireless digistat use 4 core live, neutral & as with hard wired
