I am having a lot of problems with my vokera linea 28. The trouble I'm having is that I keep getting an error code 01 coming up. The code comes on when the central heating is being used. Once I turn the switch to off/reset then back on it fires back up again no problem. But this morning when I turned the switch to the off/reset position the boiler started up on its own while the switch was still in the off position.
The error appears randomly. It can sometime run for a days without any problem then sometimes it will only run a matter of minutes. I have had a couple engineers look at it but typically the fault does not happen when they are here.
So far I have tried changing the thermistor but if anything that seems to have made it worse. Also the problem seems to occur when the weather outside temperature is low.
Has anyone had a similar problem or have any suggestions as to what my problem might be.
