Hi, My boiler (8 years old) is causing problems with hot water supply to the bathroom. The water downstairs runs hot when the tap is turned on at any power, but uostairs, the water only runs really hot if the water is run at a low speed. The boiler has been looked at 4 times now by a corgi registered engineer and the venturi has been cleaned and new valves have been put in (sorry can't remember which ones) The engineer now says that he believes it to be a problem with either the thermostat on our Aqualisa shower letting in too much cold water when the shower runs and having a knock on effect on the taps when they run after this. Alternatively he says that the cold water pressure coming into the house is too high and is affecting the boilers ability to keep the water hot. He says that the boiler is absolutely fine...does this seem reasonable??
- when the shower is running, if it is run on a lower heat setting for a minute and then the heat setting is increased, we get lovely hot water for about a minute then the temperature drops again.
