vokera linea divertor valve kit
29 Jan 2011
Ayrshire
Hi there. At a Linea 24 tonight. Working fine on HW mode. The pin on the right hand side of the divertor valve is moving forward and making the microswitch when a tap is opened, but the boiler is completely dead in ch mode. I took the actuator head off and opened a tap, this let the radiators warm up, and cold water came out of the tap. I believe the actuator is ok, as it moves the pin in and out once only, when the boiler is first switched on, which I think is normal for this boiler. Is a service kit for the divertor valve likely to solve this one?
Sorry posted here instead of the combustion chamber. Please ignore. JOHN7
As you can see I've post both messages on both forums by mistake. It's
ony meant to be on this one, the combustion chamber. Sorry it's late, and it's been a long day. john 7
John, YOU can edit each posting above to ---- and then report to a mod to have the thread deleted.
All days are 24 hours ( unless there is a leap second in which case its a second longer ).
Tony
