I have a Vokera Linea Max (6 to 12 years old?). The boiler has recently started this fault. The boiler jets fire but go out within about 3/4 seconds. It does this continuously once it has got up to temperature. Reading the manual it appears to do this once the 120mA modulation phase is entered.
This is the same on DHW and CH.
There are no error codes displayed.
The Fan, flue pressure switch, 3 way valve and pump all test ok.
I have today fitted a new safety thermostat and Primary thermister with no change.
I intend to fit the recover thermister into the DHW flow pipe tomorrow "just in case" it is that one.
Using a multimeter the modulation voltage at the coil stays around 30Vac.
I am starting to think it is the ignition control board or the main electronic board. Is there any tests I can do to eliminate these two etc.
Any advice would be greatly appreciated as we are living in the kitchen with an electric radiator.
Ian
Ian
