Hi, just wondered if anyone has come accross a similar problem as described below. Any help would be appreciated !
Looking at the old 7 series Linea, which true to form is having problems on the DHW side. I can only get out DHW at a temp of 42 Deg C maximum no matter what the flow rate.
The boiler has just had fitted new thermistors and a Plate heat exchanger.
I know its not the diverter as no heat passes to the heating circuit. I can get v.hot water by disconnecting the thermister and connecting a loose one.
There were a few problems originally when the DHW thermister was replaced as Code 6 kept flashing and wouldnt reset, so I'm presuming a pcb fault - does anyone concur ?
Cheers in advance !
Cheers in advance !
