Hi all,
I was at the above boiler tonight(intermitting fault)
Boiler would work fine then come up 01,when boiler did fail to ignite there was no attempt of a spark,pump and fan both coming on and air pressure switch working correctly.I was leaving the hot tap running and switching boiler off at control knob,more often than not it would light but occasionally would lock out (01)
I'm thinking along the lines of ignition board(sticking relay) as I think it's too erratic to be gas valve
