Vokera Linea 24 old!
No DHW it only goes up to about 30deg on the display then flame goes out and repeats when in DHW only mode.
-In ch mode the heating seems to work slightly better but still no DHW
-It had an ignition pcb fitted last time it was serviced
-I have swapped both thermistors which both read 9ohm(dhw) & 10(main)ohm when out of circuit (the dhw therm was covered in limescale build up)
-I also cleaned out and checked the seals and pressure switch parts (the -
circuit was very dirty and seals have seen better days).
-I am thinking of ordering a new seal kit and diaphragm etc + thermistors?
-If this don't work then maybe call the lads out for a pro opinion
Any thoughts? i also suspect a pcb but maybe because i'm elec biased[/b]
