VOKERA MAXIN 24E
background- my central heating for some time has not been maintaining the 1.5 bar pressure. i checked high and low and could not figure where the leak was coming from, and would top up pressure at least once a day. But the boiler itself worked fine. (this been going on for 3 months)
eventually i found that the main heat exchanger was leaking, so i removed it, had it repaired and refitted it along with new insulation pads.
now when the ch is on, the boiler will fire up and stay on for about 3 min and then will start to go on and off every 30-40 sec.
i have noticed that if i disconnect the temp thermistor (for test purpose) the boiler will stay on, (if that helps).
few other things i notice which my be of help.
-the DV pin is still making contact with the micro switch when this happens.
-the grundfos pump is running
-although the hot water works i have noticed that since replacing the main heat exchanger it has not been as hot as it usually would be.
ANY advice on possible causes will be greatly appreciated...
