I had a new ignition box fitted last year because it kept locking out and it's been OK since, until I began using the central heating this year. Now it just stops heating the water but doesn't lock out, and the pump keeps running. If I switch it off, it will start up again most times, though sometimes I need to wait 30 seconds or so. It has gradually got worse over the last two weeks, but will occasionally run for a couple of hours, though it's usually only 20 minutes or so. I thought it might be the ignition box again, but this evening it went off while I was in the shower. I assume the ignition box doesn't come into play while the shower is drawing water. Anyone know what the problem is so I can tell the plumber? I don't want him changing parts until it works and charging for all the parts that didn't need changing.
