Sorry if this has been answered elsewhere, I did a search but i'm still unsure.
A few months back, the boiler pressure would rise really quickly then the blow off valve would open and dump a load of water into the back garden. From reading on here, I diagnosed the problem to be a faulty valve on the expansion vessel.
I pumped the expansion vessel back to 1 bar with a foot pump, and it solved the rising pressure problem.
Recently, every couple of days the boiler it looses pressure. (Checked the pressure on the expansion vessel and its fine) This pressure loss is usually accompanied by a small pool of water on the worktop below the boiler. I had the cover off the boiler and it appears the water is coming from some sort of valve or pressure release outlet on pump. (Its a little black plastic cylinder that looks like a car tyre valve cap with a little slit in it on the top right hand side of the pump assembley). Its been going on like this for a month or so.
Also I have noticed that the hot water pressure has dropped over the last couple of days.
I read that the hot water pressure problem could be a fibre washer somewhere that needs looking at, so the hot water pressure thing could be unrelated?
I also read that the pipe from the pump to the expansion vessel could be clogged. Going to try have a look at it over the weekend, so any advice you chaps could offer would be greatly appreciated.
Jim
Jim
