vokera room thermostat
28 Feb 2007
Kent
Hi ive recently had a vokera unica condensing boiler installed and at present I have no room thermostat just individual ones on the rads.
I was looking to buy a wireless programmable one however ive discovered the price of the proper vokera one is £150 if not more. Im not paying that sort of mone but ive seen online you can get ones by other makes (for instance TOWER RF ECO ET4) for £45.
Will these be compatible with my boiler and why are they so much cheaper?
Thanks as always
Ok the honeywell ones are still about half the price of the vokera so ill go with that.
So they should be totally compatible with my boiler?
I just wondered if thats why they are so expensive maybe only vokera ones work or something
Were you looking at the Open Therm unit (code 611) which is something far more sophisticated than a simple room stat? Works well I'm told with a Unica but feature rich.
They do a wireless roomstat timer with a flying lead that connects straight into the boiler. Should be less than the figure you've quoted, much less. code 20029494. That model is a 24 hr timer but a seven day unit is out soon if you know your movements seven days in advance every week.
ok thanks guys I was looking at a wireless 7 day one.
I will go with the honeywell one then looks good and quite reasonable price
thanks again
