vokera syntesi fault
8 Oct 2003
Bristol
Hi got a lockout fault with one on these, goes through ignition sequence and lights for 10 seconds then drops out, the ignition sparks for 8 seconds. It faults with A1 which points to ignition lockout but its had ignition pcb, transformer, electrode and lead. I'm stumped......any ideas?
as this is a combustion/safety device problem you will have to ask in the Combustion Chamber section , you are unlikely to get the answer you need on the open site
Hi slug, polarity is fine. It seems to work on some sort of pressure regulating air pressure switch which controls the gas valve. It's a wierd setup.
ian thanks but I have no interest in joining a closed club..freedom of information all the way for me.
