Hi Ray,
thanks for your info, checked out hot water only, would seem to be ok, boiler cuts out as soon as tap is turned off.
Think the sensors could be at fault, as soon as hot tap is turned off the temp immediately jumps up at least 20'C, some times it keeps going up and up fluctuating up to as much as 95'C then back down again the it will settle around 45>55'C. 9If it doesn't shut down on error 07)
Last night I thought heating was ok, now not so sure, would the primary sensor(s) affect the CH though?
When the heating is on should the temp gauge read the heating water temp?
I did find a vokera site telling me error code 07 could be the primary thermister or the wiring.
have ordered new thermisters and the high limit thermostat.
Tonight after 10 minutes found the hot water in the shower went cold twice but came back hot.
Did bleed CH, topped up accumulator to 1 bar(it was low), checked and cleaned the venturi oriffces, they were clear
Any other things to try?
Thanks again in advance
