Vokera vision 30c 3 WAY VALVE CARTRIDGE - how to remove it?
16 Dec 2024
I had a leak in my boiler which I traced to the valve cartridge in the manifold. I have bought a new one and have it ready to fit but cannot for the life of me get the old one out of the manifold. It seems to be held in by 2 clips so I need to get it turned a bit to allow it to slide past the clips but I can't get it turned - anyone any tips on how I can do this?
The service manual just states 'Gently prise the valve assembly from the manifold' so not much help!
The small clip holds thr actuator motor, the large clip folds the cartridge in remove the large clip and pull the motor and the whole assembly will como out
Did you use the serial number of the boiler when ordering the cartridge? there were several versions, three to be precise.
  • 14 Vokèra Diverter Valves.pdf
