The buttons on integrated timer/thermostat control panel of my vokera vision 30C have worn and the manual on no longer works. I've purchased a replacement panel and would greatly appreciate advice on how to remove existing and fit this new one. TIA Dan
Two screws, one at the back bottom edge of the white case
One screw beneath and centre of the white control box. The box will move forward.
Remove the rear cover completely.
The module is behind the PCB so it's remove screws from both and replace. There's one connecting cable on a plug to the side of the PCB and two turquoise wires.
