- Joined
- 7 Oct 2003
- Messages
- 19
- Reaction score
- 0
- Country
Hope you don't mind me pesting you lot again. Although my house is fairly small it has been wired with only one ring main which runs front to back under the middle of the upstairs floor branching off as required (if you see what I mean). Currently the ring is off a 30A rewirable fuse (although I intend to replace the unit with a modern cu with rcd & mcb in the near future. I've extended part of the ring and added a couple of spurs). As I understand it at a load of 30A the max length of the ring (assuming voltage drop is the limiting factor - do I have to assume max current is the fuse rating for this?) will be around 37m. Given the number of time the wires have to go up and down I'm probably not that far off this figure. Is there an easy way to check this ?(I don't really want to do it on distance as for one thing I haven't yet worked out exactly where all the cables run). Can I disconnect the ring at the cu and measure the resistance of the individual wires (applying a correction for typical cable temps under load, 30 degrees? )
Should I be concerned about this reg anyway - I can't see many (any?)appliances being upset by a drop of 4% - is this figure plucked out of the air or is there some reasoning behind it?. If I am outside would there be any real probs with living with it until such time that I change the cu, put the kitchen (or at least part of it) on a separate circuit and use a 20A mcb on the ring.
Many Thanks
Jim
Many Thanks
Jim
