I am trying to use an old storage heater radial to power a socket and fixed light/pump installation outdoors, I have got a 32A 30mA RCBO to replace the current fuse in the off peak CU. (I called the electric company and asked them to switch it over to full rate)
To find which circuit at the CU was my radial I was intending to short out the phase and neutral, then use a multimeter in the CU to detect the right cable.
Despite removing all the fuses and turning the CU off, being cautious, I measured the voltage accross the ends before shorting them, and found about 5v.
Very worried I went back to the CU and found this was common with every circuit in it. I checked and it is completely isolated from the meter. There is a difference of 5-7v between all phases and the neutral bar, and the earth in the CU. (It is connected to the earth block by the meter)
This isnt normal surely, does this mean there is some short or connection there shouldnt be somewhere in the house? Why is it affecting all the circuits?
Cheers!
Cheers!
