Recently got one of these British Gas contracts to cover my combi boiler - 2 years on the run it failed on Christmas day morning !
They also come out and check/service the boiler before they accept you.
The combi is in the loft (live in a bungalow) and when the engineer came out he had one of these wand things that he wafted around and as soon as he approached the boiler it lit up red.
Straight away he said he could not touch the boiler. Did the same when he touched the loft insulation around the boiler and even the wooden roof struts.
He then got his multimeter out and showed that there was a 'stray' voltage of 24 volts.
Even did it with the power to the boiler turned off.
Got an electrician in and he found the same but could not isolate the problem.
So, now have a boiler I can't service and a problem with the electrics that can't be solved.
I'm not a spark but there are lots of cables, both ring main and lighting around the pipes near the boiler - unavoidable because of the layout of the bungalow.
Any ideas about what I can do now.
Thanks for any help.
