I was at a guy's house at the weekend and he was telling me about the problems he is having regarding dropping voltage.
In his garage were he fixes cars etc he got some new equipment which has a motor (4hp). When he runs the new kit, it runs fine. Now the guy has a well, which has a pump that works around 3000w and when it kicks in to deliver water while this new kit is working and for example he switches on the kettle, the well control kit cuts out after a while. On the display screen of the well control kit, displays a voltage of 200v which causes the cutting out.
He had an electrician out who said he needed a bigger cable going to his garage so he install a large new cable. However, the problem is still the same. The electrian now came to the conclusion that the transformer on the pole outside his house is not big enough and requested him to get a bigger one installed from the electric supplier.
It is gonna cost him atleast £3500 to fit a bigger transformer. Now using my multimeter, it appears that no matter if he switches on the shower in the house, the immersion heater or the hot powerwash outside etc, his voltage drops upto 10v per item switched on.
Surely if he was using too much power, the main fuse etc would trip and should the outside transformer be capable of supplying 230v if he has a 100a supply fuse fitted? I was just wondering if there is a chance that there is more of a fault at the transformer and instead of him paying thousands to fix, the electic supplier should instead test and repair the transformer? The supply says he has a 16 (kva is it?) transformer.
Any help would be grateful.
