Hi all.
First off i spent a year at collage doing c&g 1360 and 1240. this was over ten years ago so i know basic electric skills but not qualified.
i fitted a 10mm cable length probably a 40m run. its been in for 6 years no trouble. Now it keeps tripping.
Disconnected the live and neutral and the end of the run and it still trips.
Disconnected the earth as well and it no longer trips
Voltages between cables and the end are
L-E 240v
L-N 220v
N-E 20v
There shouldn't be a voltage of 20v between the Neutral and Earth should there.
I also disconnect at the CU so all three (L/N/E) were disconnected both ends. I then used y tester to test continuity between each wires but all combinations came back OK (OL)
So would this be inductive voltage and would this be acceptable ?
within the 40m run could possible be a cut/tiny nick in the wire due to other works but this was also 3-4 years ago however after heavy rain we have been having, water ingress could be a problem.
Trouble is the run was very awkward and its not easy to replicate.
What can i do next ?
L-E 240v
L-N 220v
N-E 20v
