Vuaxhall Astra 2004 mk4 not starting
23 Jan 2006
Manchester
Hi. I have an Vauxhall Astra mk4 1.4 petrol which doesn't start but turns over. I have replaced the camshaft sensor, crankshaft sensor and fuel pump but have had no luck. When the engine is cold it will start but after about 5 minutes it will go off by itself then won't start again. Any solutions?
First port of call for any reasonably modern vehicle is to have the fault codes read.
This can often save unnecessary, often expensive, parts changing.
