Hi
I have mk3 golf 1391 cc 4 speed model. I am having some problems now- it has done 97 k miles. It gives a grating sound when on any gears except neutral, when running, increases with acceleration, more so with lower gears(1st,second...) as the car picks up speed, it seems to be less or may be because of the road noise, I am not hearing it as much as in slow movement! Also in neutral gear when I release the clutch there is a bit of vibration of the engine that I can feel on the gear stick or judder. disappears when pressing the clutch.
is it a worn pressure plate or faulty bearing the in clutch. please help?
