VW Golf wheel nut thread size?
18 Aug 2007
Cheshire
VW 1.4 Golf, 4 years old. They are actually screws, 5 per wheel, but one of them has has its thread damaged sometime in the past. I need to get a new screw and to run the correct size tap through the hole in the wheel hub.
I work in engineering so would hope that one of my colleagues has the correct size. Anyone know what it is? Looks a bit finer than standard metric thread.
I think they are M14 with a 1.5mm pitch, If I remember tomorrow I will check for you.
Don't you have a thread pitch gauge?
Not me mate I'm an Electrician, but i'm sure someone will at work. Just thought someone might know off hand.
This is what you are looking for then.
All 5X100 & 5X112 (5-lug) VAG cars use B14mm X 1.5mm 17H (Part # B9)
Part Number............................Description.............................
......B9........................BB14X1.5 27UL AUDI/VW OE................
http://tinyurl.com/35puexc
HTH.
So you need a 14x1.5mm tap
May not be that easy to find?
Sorted. Borrowed some M14 X 1.5 taps, ran them through and new screw torqued up to required setting. Thanks to all who helped.
