I had a scan with VCDS Light and the codes are as follows:
VCDS-Lite Version: Release 1.1
Monday, 06 May 2013, 09:59:45.
Control Module Part Number: 03D 906 032 C
Component and/or Version: 1,2l/2V SIMOS3 00HS2501
Software Coding: 00031
Work Shop Code: WSC 00788
VCID: 1E4F5D7B89B9
Additional Info: WVWZZZ9NZ3Y205478 VWZ7Z0C6794547
2 Faults Found:
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-00 - -
16555 - Shareware Version. To Decode all DTCs
P0171 - 35-00 - Please Register/Activate
Monday, 06 May 2013, 10:01:08.
Control Module Part Number: 6Q0 907 379 L
Component and/or Version: ABS FRONT MK60 0101
Software Coding: 0001097
VCID: 46FFD51B71A9
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
The problem started when I took my car to the garage to do a preliminery check before servicing. My usual favourite technician was not there so, the other guy just opened the bonet and put pressure on the front of the car to check suspension. I felt it was s bit strange. He gave me a list what needed to be done. But when I drove off engine light came on within few minutes. I can see some engine oil spill. The spill is on one of the coil pack.
Do not know what he has done under the bonet.
I reset the code twice and it is coming back after driving few miles.
A big headache now.
Any suggestion will be highly appreciated.
VCID: 1E4F5D7B89B9
2 Faults Found:
P0106 - 35-00 - -
VCID: 46FFD51B71A9
1 Fault Found:
A big headache now.
