B
BigBurner
This combi says that there is no by-pass required. Does it have a flow switch if all TRVs close? Anyone fitted one?
Would that be because its already got an auto bypass built
Baxi solo HE baxi 133HE combi`s and certain suprima to name the most common there will be others out there.
So perhaps you would have been better gettin g to the end of the course instead of halfway through (soz could not resist)
All jokes aside, I would say setting up a system with no roomstat, all trv, and no bypass is asking for trouble.
I can see how a boiler could detect lack of flow, or absence rather, and use that to turn off. What I can’t see is how the boiler senses that the flow has to come back on.
It may be legal, to use a solo with a timer and all trv-controlled, but I would be a lot more confident to keep my satisfied-customer-rate high using W-B CDI with roomstat. Methinks I will get a lot fewer calls to come and see why the system does not work.
Caught another one .
The regs dont ask for a roomstat they ask for a boiler interlock ,roomstat being the most common easiest way to achieve this.
A boiler with a flow switch will also achieve this and trvs can then be on every rad.
Bigburner
The worcester instructions are as clear as mud
Says no bypass req but doesnt mention auto bypass in boiler (prob controlled by the anti cycle feature in some way)
Also says trvs on every rad on change over with possible autobypas down stream
But on new system it says leave one off in room with room stat.
Nothing in the spec mentions flow switch on heating side.
Now that doesnt add up in my book
Modulating Pump.
Modulating Pump.
If fitted to building regulations, and according to Worcester, the rad with No TRV is used and along with a modulating pump/heat output it should be ok.
Yes.
