D
Doctor Drivel
This boiler is pretty new on the market. It states no need for a by-pass. Does anyone know if it has a flow switch?
Dan_Robinson said:It uses a flow turbine, but if you look at the exploded diagram of the boiler one has to wonder - why?
Dan_Robinson said:Page 11 of the destructions says it MAY need a by-pass - so I owuld guess it uses temperatures to detect primary flow.
ChrisR said:"An automatic bypass may be required,
(downstream of the pump), in order to maintain
the minimum flow-rate through the appliance."
Can't see any direct way it can measure flow.
Even the mighty Google doesn't seem to know what that means. Care to enlighten us?ChrisR said:swym!
