w/bosch 400 rsf over heating
23 Apr 2007
London
hello people
i have a highflow 400 rsf (non electectronic) that cuts out on dhw.Safety
Temperature Limiter has to reset in order for it to work again, but cuts out gain a few hours.
i have replaced the pump, water - water heat exchanger, Safety Temperature Limiter,HW Thermostat, i have checked the filter in the white manifold, i have checked the 6mm swan neck pipe,
the boiler still has the problem!
the pump does over run
has anyone had this problem?
thanks
jose ,
Have you replaced the dhw hx for a new one?, I always replace the top manifold aswell (and the bottom as I might aswell). There isn't much to knock these out for hw only except what you have already done
hey there
i have changed the dhw hx and the two manifolds are clear.
any other ideas?
Have you been running heating demands at all?, poss. gas valve sticking.
hey
the boiler runs fine on heating its only dhw it cuts out.
how would i check if gas valve is sticking?
cheers
