Hi all i am new here so i hope you can help.
We have a worcster bosch gas fired 28i junior wall mounted boiler.The boiler was installed 19 months ago and we have never been happy with the heat output.Upstairs rads are very poor if they are all switched on.If i switch them all off bar one the one that is left open gets red hot.This works for each and all rads in turn. have bled the system(running at 2 bar)and had w/bosch out twice.They replaced the motor twice and the second guy said the boiler was working but it was short cycling but did not know why.
The boiler is giving off 59 degrees and the return is 58 degrees.The rads closest to the boiler are red hot.I have tried"balancing" the system but this has no effect on upstairs.
The feed pipes to the rads are red hot but the return pipes are cold.The rads are new(when the system was put in 19 months ago) and the hot water side is fine.I hope i have given enough info.
By the way we did have thermostatic valves fitted to the rads but i removed these after (wrongly) thinking they were at fault.i feel as a layman the pressure or circulation is low and therefore not sending enough hot water around the system? but as i am a mechanic what do i know.
On a further note w/bosch are the most unhelpfull money oriented company i have had to deal with in a long time.
