I’ve been trying to wire two 1mm solid core wires to a Wago 224-112, but when I push in the second wire, it doesn’t stay in, it just comes out with little force
I had the impression that the spring is shared between the two wires
https://www.wago.com/global/install...tors/2-conductor-lighting-connector/p/224-112
The specs show it can accept between 1mm and 2.5mm cable, however the connector itself only has 2.5mm printed on it
I wanted to use these connectors as they are the ones suitable for the light wagobox, but I ended up using these
https://www.wago.com/global/install...h-wire-connector-for-junction-boxes/p/773-104
