hi I need to blank off 2 double sockets in a room that is going to be used as a bathroom. would 24 amp rated wago connecters be suitable to use . thanks stuart
Those connectors and others like them are only maintenance free when correctly installed into a suitable maintenance free enclosure.
Cables must remain in zones defined by the accessories, so just hiding them in the wall is not permitted.
hi flameport / 333 rocky 333 thanks for the advice I will now be removing the sockets / cable from the room. really apricate the sound advice that you have given thanks stuart
