Wondering if anyone else has had a similar issue. We moved into our semi just over 3 years ago. The previous owner built a large loft extension shortly before we purchased, presumably under Permitted Development rules. We have the buildings reg certificate sign off dated June 2011 (we moved in November 2011), but no certificate confirming it met PD conditions was ever obtained. In hindsight we should have pushed for this at the time we moved in but assumed all was above board.
Issue now is we want to apply for a 5metre rear extension, and for semis you have to make an application to the council for this to get it done under PD (as opposed to a 3 metre extension which you can just go ahead and do it without notifying the council). Problem is we now suspect the loft conversion was too large for PD (approximately 7-10 m3 too much) and therefore if we put an application in for the rear extension potentially the council may start digging around the loft extension and could cause problems. The drawings presented would need to show the large rear dormer so they may flag it from that.
Simple choice is to wait until June when the loft extension will be 4 years old, then apply for certificate of lawfulness for the loft extension (under 4 years old rules) then proceed to apply for the extension. Problem is now my next door neighbour (attached) is likely selling up before then, and we have no idea if the new neighbour would object to the 5m extension meaning we have uncertainty about whether we can proceed at all!
It's frustrating as we're all ready to go funds wise. And we have building reg sign off on the loft, just not planning.
Does anyone know if the council would be likely to investigate an older extension when making a new application? If they did would they really go to the lengths of refusing retrospective planning permission for a small breach of 7-10 m3?
Should i just wait till June instead, and get the loft retrospectively approved, to be on the safe side.
