Hi, I need some advice on tile spacing, would really appreciate your help on this.
I plan to tile my bathroom with 20x20cm and 10x10cm stone tiles, in a brickwork style. The wall tile pattern will go: Two horizontal rows of 20x20cm, 3 rows of 10x10cm and so on, using 4mm and 2mm spacing respectively.
My dilemma is;
I want to use the same tiles and pattern for the floor, can I still use the same spacing sizes of 4mm and 2mm? I understand that 5mm is recommended for floor tiles but that would screw up the bicking patter and these a small-ish tiles. What do you guys recon?
Thanks, Shaun
My dilemma is;
Thanks, Shaun
